Hi everyone.
I'm trying to do something like sandman from “rise of the guardians”, i have al ready made something like the follow path of the sand and the build objects, but my brain is burning out and cant figured out how to make the objects vanish after they hit something.
To make the objects like sand appear and desappear am using an object to object blending, with scatter, so the points stick to the goal object. I'm trying to unstick it and make it look like they just vanish after they hit something or in an specific frame.
Hope you guys can understand what am trying to do, if you want i can upload some example file.
Sandman kind of particles
4677 9 2- JasonLeandro
- 73 posts
- goldfarb
- 3456 posts
- JasonLeandro
- 73 posts
Thanks Arctor,.
Now that you have help me with that noob thing hahaha, can you help me to figure out how can i make each particle rotate? Is some kind of SOP? I´m trying to use the Houdini Engine for maya, i can export everything but the particles don´t spin, or is it maya that don´t read that attribute. Can´t make it work.
- JasonLeandro
- 73 posts
- Sadjad Rabiee
- 1391 posts
jason leandro brenes
To be more clear, i have this little example, i want that this particles rotate each one.
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=34401 [sidefx.com]
- Sadjad Rabiee
- 1391 posts
If you wanna use Point's blending method for your project , It's not good idea to scatter some points on different objects and blend these points.
I made another method for you with some notes about how it working :wink:
- Sadjad Rabiee
- 1391 posts
Also I suggest you to see this Tutorial from cmiVFX , you will learn some tricks and tips about this project on it :idea:
https://cmivfx.com/store/568-houdini-mograph-title-design [cmivfx.com]
- JasonLeandro
- 73 posts
- Sadjad Rabiee
- 1391 posts
Yes , he explained a weird and impressive method for morphing points between two shape with a clever way .
Also cmiVFX has another tutorial about particle's morphing , Of course I didn't see it , But I think it can help you too :wink:
https://cmivfx.com/store/564-houdini-particle-morphing-effects [cmivfx.com]
- JasonLeandro
- 73 posts
