Hey guys, I don't know where to post it, so I'll publish it here
I have this weird problem with redshift materials, I haven't found anything on internet.
This happends in a clean scene, only adding a standard RSMaterial, the .env file is setup like this to point to RS install folder.
PATH = “C:\Redshift\bin;$PATH”
HOUDINI_PATH = “C:\Redshift\Plugins\Houdini\16.5.378;&”
If anyone could help me, I would appreciate it!
Jason Leandro
Houdini Redshift problem
13849 11 2- JasonLeandro
- 73 posts
- TwinSnakes007
- 606 posts
You can post questions about Redshift on the Redshift3D forums [www.redshift3d.com]
The latest Redshift HDK version is .405, so you probably need to update your Houdini.env file to use that plugin version.
Also, /shop context is deprecated and should not be used for new content - the /mat context is the preferred method going forward.
HOUDINI_PATH = “C:\Redshift\Plugins\Houdini\16.5.405;&”
Edited by TwinSnakes007 - April 18, 2018 09:00:40
Houdini Indie
Karma/Redshift 3D
Karma/Redshift 3D
- JasonLeandro
- 73 posts
- TwinSnakes007
- 606 posts
Oh, if you want to do a custom installation of the Redshift plugin, you have to set some environment variables.
If you use the Installer, it sets everything up for you.
Glad you got it sorted out.
BTW, what version of Redshift are you using?
Edited by TwinSnakes007 - April 18, 2018 16:09:53
Houdini Indie
Karma/Redshift 3D
Karma/Redshift 3D
- JasonLeandro
- 73 posts
Yeah here at work the Sup wants to create a custom installation, same as he did with Maya, we're setting up a pipeline based in proxys, that's because the render farm is all set up for maya
I was hoping proxies could read volume data, but sadly… no
I'm using the latest version RS 2.5.66 with H 16.5.378
- TwinSnakes007
- 606 posts
Proxies can definitely store Volume data. Anything Redshift can render, can be stored in a Proxy.
Here are the custom installation Docs for Maya [docs.redshift3d.com].
Houdini Indie
Karma/Redshift 3D
Karma/Redshift 3D
- JasonLeandro
- 73 posts
- TwinSnakes007
- 606 posts
- JasonLeandro
- 73 posts
- TwinSnakes007
- 606 posts
- JasonLeandro
- 73 posts
- JasonLeandro
- 73 posts
