Is it just me or is autoseam really unstable. It keeps crashing Houdini with segmentation faults.
eg:
1. Create a box at default location
2. Navigate inside the box geo and press Tab–>autoseam node.
3. As soon as you drop the node it crashes.
Houdini v17.0.352 apprentice, Win10 1803, nVIDIA 980Ti on 390.77 (though i've tried with latest 416.34 drivers also)
UV Autoseam crashes.
7654 10 1- gumsax
- chrism
- 2493 posts
Hi! Please log a bug with all your system specs. Thanks!
https://www.sidefx.com/forum/topic/15603/ [www.sidefx.com]
Chris McSpurren
- Doudini
- 333 posts
- Symber
I have been able to determine that a number of tools currently fail when you use the shelf to insert the geometry.
The following also fails:
1. Ctrl + Select Grid from shelf
2. Drill into object node to access geometry node
3. Tab key and select Bend Operator
4. Place Bend Operator into node view
At step 4 the process fails.
If you follow this procedure it will not fail:
1. At Object level
2. Tab key and select Geometry and place in object node level
3. Double click to enter geometry node
4. Tab key and select Grid (or other primitive node)
5. Tab key and select Bend Operator (or other modifying operator)
6. Place in node view
It seems that something in the shelf tool has caused the basic operators to fail when being placed.
Regards
1. At Object level
Regards
Edited by Symber - Nov. 6, 2018 20:37:01
- Danil Shaposhnikov
- 58 posts
- Werner Ziemerink
- 1265 posts
- BSchultz
Symber
1. At Object level
Regards
Has this been logged as a bug so it can get fixed?
- hashman63
- 11 posts
- 58 posts
- mohitsherman
- 27 posts
When I apply texture while doing UV's, no matter what option I click my Houdini Crashes with “Fatal Error Segmentation Fault”.
I have re-installed my RTX 2070 drivers but still same error. I am unable to work further and tweak my UV mapping.
My Computer is Ryzen7 3700X
Please share your thoughts, How can I avoid this error and frequent crashing of Houdini.
Edited by mohitsherman - Oct. 6, 2019 21:26:08
- mliuzzi
