Node Info box.
4052 6 2- Graco123
- 13 posts
- 7837 posts
- tranasaurus
- 43 posts
I'll try the ctrl-middle click.
jsmackAs you noted that I could click on the ‘i’, but that is what I was doing. I'd click the ‘I’ and the info box would disappear before I could click the “display” option. Acted buggy.
ctrl-middle click to open info window without it closing instantly. Or if you have node rings enabled, you can click the ‘i’ on the left side of the ring.
- anon_user_37409885
- 4189 posts
- FFD
- 80 posts
I had this same problem intermittently on Windows 10, if anyone else is having this issue I found this helps:
Edit -> Preferences -> Network Editor, Nodes, and Trees -> Uncheck “Node Info Window Close When Losing Focus”
The info panel will then stay open regardless of where you go in the network view but I actually find this better with bigger networks and you can always just middle click on any node to clear it.
- eikonoklastes
- 334 posts
- Noboru_Garcia
- 75 posts
