Hello!
i'm learning grooming with Houdini and i've a problem for the redshift proxy export.
I'm trying to export my main fur for the test a render in maya/redshift but when i'm try to export with the redshift proxy output the file which was exported is empty or 7ko.
Who know's where is my error?
Best regard,
problem with redshift proxy export
3744 5 1- dylanmonin
- edlgm
- 11 posts
- MorganMcD
- 24 posts
Having a similar issue. But I was able to write proxy files that worked. Later I went back and changed a texture on the material and exported the same proxies again. This time it wrote empty files. Still trying to figure it out but everything I try only writes empty proxies now.
Will post back here if I find a reason for it.
- cdordelly
- 140 posts
Hi!
You should try to post an basic repro file on the Redshift forum to see if Juanjo can find the problem:
https://redshift.maxon.net/category/26/bugs-houdini [redshift.maxon.net]
Cheers!
Cheers!
- Andi Farhall
- 115 posts
- MorganMcD
- 24 posts
