WIP - TurnTable Object Node [Houdini Utility]
15462 13 6- JohnFanny
- 19 posts
HDA Now Available!
Your feedback is precious to develop the better experience possible. More in the next post.
Description
• Create Turntable Setup for Look dev.
• Chrome / Matte Ball Overlay on camera or free stand.
• Rotate Model / Lights / Cameras
Features
• Rotation
- Model, Camera, or Light just by connecting the node to it.
- 360° Rotation based on playbar's frame range.
• Spheres Layout:
- Compact: Chrome / Matte Ball side by side
- Vertical: Chrome / Matte Ball above the other
- Realistic: Chrome / Matte Ball with Stand asset.
• Transform:
- Compact / Vertical: Position left / right, rotation and scale
- Realistic: Transform / Rotation / Scale
• Color Chart: Optional Color chart
• Backplate
- Procedural Backplate
- Created only on-camera frustum, avoiding blocking light.
- Backplate from any angle
• Shading:
- Materials assignment for the asset (balls, chart, stand, and backplate)
Use Cases
• Create quick turntable
• Avoid recreating setup each time
• No need for a dedicated scene.
Edited by JohnFanny - Sept. 28, 2021 21:25:40
John Fanny | Fx Apprentice
- JohnFanny
- 19 posts
- Ruthie
- JohnFanny
- 19 posts
Ruthie
Hi! I am trying to use your HDA but had a question. The realisting option in the parameters makes everything dissapears, maybe because the file is missing, so are the textures and this file somewhere?
Or its something I have to click on and I missed it?
Thank you!
Hi Ruthie! Thanks for your feedback!
You were right, there was a missing reference.
Here is the updated version, feel free to give it a try!
Edited by JohnFanny - Nov. 21, 2021 06:32:39
- Grendizer
- 375 posts
- Grendizer
- 375 posts
- JohnFanny
- 19 posts
Hey Grendizer, thanks a lot for testing the tool!
Unfortunately, the tool is not in Labs.
I fixed some issues in the next version of the tool, you can find it here:
https://drive.google.com/drive/folders/1oNem-N-K4DjjsfXFuZ2bNBFP3CbrqkTb?usp=sharing [drive.google.com]
Concerning your questions:
- The tool doesn't have textures,
- The material library is available with the search icon in the shaders section,
However, you can assign your own shaders to the geometry.
- The camera from the tool is not made for use, you just have to plug the tool into your actual camera.
You can refer to this video: https://youtu.be/cEmrvDDTQPw [youtu.be]
Thanks again for your feedback! Give it a try and tell me if it's working properly!
Edited by JohnFanny - July 23, 2022 13:11:12
- Grendizer
- 375 posts
- Grendizer
- 375 posts
- Tash3952
- Grendizer
- 375 posts
- JohnFanny
- 19 posts
- h326870330
Excellent work! Sorry that I can't get the realistic stand.Do you mind you share your lookDev_ref.abc? So that we can reference it into the HDA.Thanks a lot!
- Grendizer
- 375 posts
Hello John
I just finished testing your latest version : v1.5. I didn't notice any issue with it. Some comments :
- Previously, the /obj level node had to be called "TurnTable1", one could not rename it. This seems to be fixed in v1.5!
- The object will turn in an anti-clockwise direction. Is it possible to add a Clockwise rotation?
The first post does not have any link to the file. Do you mind if I add a link to your Google drive here? So other people can download and test it!
Gz
Gz
Houdini gamboler
