Karma - Texture Baking
2965 9 1- cdordelly
- 147 posts
- 8622 posts
that's probably what preliminary support means
no high level tools, but technically it may be possible on lower level
like for example, Render Settings LOP has whole section of properties in Karma/Texture Baking
but I don't know whether they are sufficient to put together a working baking setup as I haven't tried
- mestela
- 1748 posts
I got this going back on the alpha with some hints (ok, a LOT of hints) from Mark Elendt.
It's fiddly, but it works:
https://www.tokeru.com/cgwiki/HoudiniLops#Texture_baking_with_Karma [www.tokeru.com]
- cdordelly
- 147 posts
- pablo_lukaszewicz
- 6 posts
- 7837 posts
pablo_lukaszewicz
Sorry for a noob question but what is this Object ID thingy.
If instead of one pig head as in the example I would have two usd primitives pigHP and pigLP how do I tell which one is wich to the render rop? I need to mark them with some attribute with some fancy name?
Yes, the render geometry settings has Low, Cage, and High obj ID settings for correlating the primitives that are baked.
- nimbus_hipthrust
mestela
Thank you so much for this helpful post. I can't wait to start some baking in my karma OVEN!
- Soothsayer
- 862 posts
jsmackpablo_lukaszewicz
What are these ID settings? An integer, a string? Are they applied automatically and how do I find them? For example, if I have a cube and a sphere and I want a baked texture of only the sphere (but with the shadow cast from the cube, etc). Is it possible to set those ids?
Edited by Soothsayer - Feb. 22, 2024 11:02:46
Jobless
Jobless
- pablo_lukaszewicz
- 6 posts
- pablo_lukaszewicz
- 6 posts
