Export and import node sets (help wanted)
   710   2   0
Here's a prototype of something that works on Linux (with dependencies met). It need some updates to work on all platforms and versions, but I'll leave that to the Houdini community. Installation instructions are in the top of the code.
Shelf tool 1:
from pathlib import Path
# set some variables
path_user_home = str(Path.home())
network_snippets_path = path_user_home+'' # set the suffix '' as desired
def loadPyNode():
    '''Import node from py. See saveNodesAsPy. To install: For example, add this code to a shelf and add a hotkey (for example: Ctrl+Shift+V). Then run it from the Network Pane. Remember to follow the EULA of the software (SWest).'''
    kwargs = {'node': '', 'parm': '', 'script_multiparm_index': '-1', 'script_value0': '0', 'script_value': '0', 'parm_name': '', 'script_multiparm_nesting': '0', 'script_parm': ''}
    path_and_filename = hou.ui.selectFile(start_directory=network_snippets_path,pattern="*.py *.png *.jpg",title="Load node as Python")
    if path_and_filename.endswith(".png"):
        path_and_filename = path_and_filename.replace(".png",".py")
    if path_and_filename.endswith(".jpg"):
        path_and_filename = path_and_filename.replace(".jpg",".py")
    if not (path_and_filename == ""):
        exec(open(path_and_filename).read())
loadPyNode()
Shelf tool 2:
import os
def saveNodesAsPy():
    '''Save a single or a set of nodes as Python code including parameter settings to storage medium.
    The code is generalized so it can be imported to any compatible node parents. Use regular folders to organize nodes. This function support the creation of an optional thumbnail file that is also supported by the equivalent load function. This tool extends the existing functionality of the shelf. To install: For example, add this code to a shelf and add a hotkey (for example: Ctrl+Shift+C). Then run it from the Network Editor. Remember to follow the EULA of the software (SWest).'''
    import toolutils
    def getNodeType(node_path):
        node = hou.node(node_path)
        type = str(node.type().name())
        return type
    # a selection should look similar to this:
    # /obj/char_workflow/char_rig /obj/char_workflow/OUT /obj/char_workflow/null1
    selection = hou.selectedNodes()
    nodepath_or_list = []
    for node in selection:
        nodepath_or_list.append(node.path())
    # print(f'selection: {selection}')
    # print(f'nodepath_or_list: {nodepath_or_list}')
    tool_script_for_node = toolutils.generateToolScriptForNode(nodepath_or_list)
    node_path = str(selection[0].path())
    node_name = str(selection[0].name())
    node_type = getNodeType(node_path)
    title = 'Save node as Python - '+node_path
    default_value = node_type+"_"+node_name
    path_and_filename = hou.ui.selectFile(start_directory=network_snippets_path,pattern=pattern,title=title,default_value=default_value)
    if (path_and_filename == ""):
        hou.ui.displayMessage("Filename is empty. Please try again.")
    else:
        if not path_and_filename.endswith(".py"):
            path_and_filename += ".py"
        node_file = open(path_and_filename, "w")
        node_file.write(tool_script_for_node)
        node_file.close()
        # show message: press ok to capture a screenshot
        user_choice = hou.ui.displayMessage("Press Ok to take a screen shot.", buttons=('Ok', 'Cancel'))
        # user_choice 0 (Ok); user_choice 1 (Cancel)
        if user_choice == 0:
            # set filename
            path_and_filename = path_and_filename.replace(".py",".png")
            os.system("xfce4-screenshooter -r -s '"+path_and_filename+"'") # use same path
            # resize the image
            from PIL import Image
            basewidth = 64
            img = Image.open(path_and_filename)
            wpercent = (basewidth/float(img.size[0]))
            hsize = int((float(img.size[1])*float(wpercent)))
            img = img.resize((basewidth,hsize), Image.Resampling.LANCZOS)
            # save thumbnail image
            img.save(path_and_filename)
saveNodesAsPy()
Edited by SWest - April 18, 2024 14:51:58
Did you know you can save a subnet to a gallery ?
Yes, do you know the difference?
This tool is rather very similar to the shelf already implemented. The difference is that content (node structures and their parms) can be organized using regular folders and files, and saved to backup selectively.
The exported code can also easily be analyzed when needed.
If you want to do a simple export of a part of your network so you can continue with it at another place you could email the code or the file. This would work with the shelf, but it just become much quicker and simpler.
No (secondary) asset data like geometry or equivalent is stored, however, so it is probably most useful for prototyping or quick tests especially with code in parms.
Edited by SWest - May 9, 2024 13:13:28
