Hi!
I want to ask something about the process of convert HDA nodes into MtlX. I'm a bit familiarized with the process thanks to the Shader Guy [www.youtube.com] video.
Right know I have the three process working correctly (vop2mtlx, mtlx2hda and mtlx2karma), I already converted some shaders.
Now I want to ask if there is any way to export an UI that is not represented as a node input, for example an Ordered Menu that controls an internal Switch node, this kind of menu:
Or which can be the method to have a menu like that controlling an internal switch node? Right now I only copied the parameter as relative reference to the switch controller with no success, the created mtlx node has only the color inputs that I created with the Subnet Input Connectors, but nothing from the Ordered Menu that the HDA has on the UI controlling the switch, and the ordered menu values are float to be compatible with the Switch "which" parameter.
Maybe I need to create the menu manually on the mtlx file? Let me know if there is something I can do,
Vop2mtlx: UI with no input connections - Ordered Menu
357 3 1- cdordelly
- 140 posts
- cdordelly
- 140 posts
- rafal
- 1450 posts
MaterailX shader nodes have only inputs, thus only VOP node inputs get translated to materialx. However, your channel reference approach (to the 'blend_mode' top parameter) should work, since ultimately you are setting a value on a MaterialX shader input.
As for the color-space value, in MaterialX, they are authored as an attribute of the input element. But `vop2mtlx.py` might not be handling them properly. It, it may be a bug/limitation of that script.
- cdordelly
- 140 posts
Hi Rafal, thanks for your answer.
Yes the `vop2mtlx.py` probably can't translate Ordered Menus indeed, I found that there are a few mtlx nodes with menus, like the Place2D node where the menu is a int parameter, I tried to convert the ordered menu on a int menu but with no success, it is not translated either as you can see on this test video:
