I've been tinkering with APEX a lot lately.
With kind help from many people, i've created the following setup:
till now, I have understood the following:
I start with a mesh, & a 'Skeleton' with Joints.
Then i weight paint.
Then i connect a 'rig pose' node & create a pose. This pose will be used as a blendshape later. ok.
Now i connect all three (mesh, skeleton, rigpose) to a 'pack folder' node.
in Attributes, i input the mesh as .shp', 'Skeleton' as .skel, and 'rig pose' node as .skel as well.
Then i create Auto rig component with 'FK Transform'
Then i create Auto rig component with 'Bone deform' node
now i connect 'unpack folder'. then 'edit graph'
in the APEX subgraph, in the 'parms' node, i have inputs for mesh.shp, default skeleton.skel and rig pose.skel
***** i dont know what to do next****
i can search for skeleton blend, aka sop::kinefx::skeletonblend::3.0, but
i dont have knowledge about any of this stuff......
i also want to know how to create an 'abstract control' to drive 'nblends' of skeleton blend as well.
Link : https://www.youtube.com/watch?v=bFbaRI6paIQ [www.youtube.com]
in the above video, i 'show' my current kinefx setup with 'skeleton blend'
i don't know how to replicate it in APEX.
I'm not a rigger. Just a hobbyist.
Hopefully, Some kind soul will Come up with Solution for This. Thanks.
Skeleton Blend for Blendshapes in APEX
790 5 0- playboy241994
- 4 posts
- william_harley
- 21 posts
- playboy241994
- 4 posts
- Max Rose
- 45 posts
- william_harley
- 21 posts
Max Rose
I've attached another way of going about it, based on Will's Chicken and Lucha rigs.
@william_harley what I'm using here is the blendshape method, where you treat the points like geometry and while looping through each joint. Is there a benefit to using the skeleton blend over the blendshape node?
Technically the skeleton blend is pretty much doing exactly what I was doing in the chicken and luchador setup. The big difference is the pre setup. With the skeleton blend you don't have to worry about managing the skeletons like I did, you can simply add them to the folders and plug them in and it will work.
Whats nice about apex, is that you are not limited to using specific tools to achieve a task. You should feel free to get creative with building your setups. I do think some tools are better for specific tasks, and the skeleton blend has been developed specifically for this and should preform better.
- Max Rose
- 45 posts
william_harleyIf that's the case then awesome. The setup I have for skeletal blendshapes is mind-numbing.
