Turn on Red Blue Green Input Transform Parameter Window
2788
3
1
chanson78
Nov. 24, 2020 11:03 a.m.
Where do I enabled the red green and blue lines in the inputs for rotate and translate in the transform parameter window? I can't find this anywhere.
Screenshot 2020-11-24 165216.jpg (138.4 KB)
Ivan L
Nov. 24, 2020 1:54 p.m.
Hey, It seems to show those only if you set a keyframe
I contribute to the beauty of this world
chanson78
Nov. 24, 2020 2:05 p.m.
deviner Hey, It seems to show those only if you set a keyframeNo keyframes here. They only show on the obj level but not in the sops level. It would be convenient for example with the transform sop in the sop level.
Screenshot 2020-11-24 200411.jpg (140.6 KB)
Screenshot 2020-11-24 200448.jpg (156.7 KB)
jerry7
Nov. 26, 2020 7:52 p.m.
This setting defaults on in H18.5 that in preference>Animation>Underline in the parameter editor. But the parameter must be selected first. You can RMB menu in parameter and check Channels> auto-add
