How to assign a shortcut key for enabling/disabling simulati
233 1 1- lebbit
- 1 posts
I want to assign a shortcut key for enabling/disabling simulations using Python code. I found that shortcuts can be assigned with a script like hou.hotkeys.addAssignment(hotkey_symbol, key). What I’m curious about is what the hotkey_symbol that represents enable/disable simulations is, the one that I can write inside the parentheses.
- Enivob
- 2561 posts
Place this code inside a shelf tool, and assign F6 as the hot key. It will turn on and off Auto Update. (lower right corner)
if hou.ui.updateMode() == hou.updateMode.AutoUpdate: hou.ui.setUpdateMode(hou.updateMode.Manual) else: hou.ui.setUpdateMode(hou.updateMode.AutoUpdate)
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
